white/grey smoke - Ford Powerstroke Diesel Forum
Old 01-14-2013, 01:34 PM
white/grey smoke
We have an '06 6.4L and we just replaced head gaskets, new ARP Studs, rebuilt Injectors from Warren Diesel, Blue Spring kit upgrade, Coolant Filter kit and EGR Delete from Sinister.
Truck ran magnificent for two weeks both towing and non-towing. Went to the jobsite today with no problems. Went to come home and upon cranking she was running very rough, like she was skipping. We babied her home (about 10 miles) and about three miles from home at red light, she started blowing heavy white and blue smoke. She blows smoke until about 1500 RPM. We pulled over and had a roll off come and get us.
There's no bubbling in Degas bottle and no coolant in oil pan.
Anybody able to help me?
Old 01-14-2013, 01:40 PM
MAD - Modification Addict
Feedback Score: 7 reviews
If you have a 06 you don't have a 6.4l you have a 6.0l...
What does the smoke smell like? Excessive fuel or sweet coolant smell?
Most likely a injector stuck open. Careful trying to start it because it can leak fuel into the cylinder(s) and hydrolock it and if that happens and you keep trying to crank it over it can/will bend a rod.
Also keep an eye on your oil level. If it starts to rise (making oil) you are leaking fuel past the rings in the cylinders and it is ending up in the crankcase and will need to be addressed ASAP.
Do you have anyway of reading or scanning for codes? See if it is throwing any contribution codes or imbalance codes.
Old 01-14-2013, 01:53 PM
You are right. It's the 6.0. My other is the 6.4.
Smells like fuel.
There is no CEL. Would there be a code w/o a CEL? You had mentioned previously to me, when you recommended Jesse from Warren Diesel to do the injectors, that I get a monitor. Would that tell me if I had a code?
Thanks
Old 01-14-2013, 01:54 PM
You need a good monitor or scanner software and pull the codes. Yes it can throw a code without throwing the CEL.
Old 01-19-2013, 07:06 AM
Got a Livewire, no codes....ARGG. I think the dealer got tired of us bringing the truck to them and disabled DTCs LOL.
Came to the braintrust (That's powerstroke.org) and read a bit and decided that we should pull all the glowplugs and turn the engine over to determine which cylinder was blowing fuel.
We did this and found that #4 was blowing (It was VERY obvious). Don't get your face too close to your engine block, LOL.
After pulling the #4 Injector, we found that it wasn't "STUCK", the lower O-Ring was blown.
If this happens to you, BE SURE that you inspect/clean the head-bore that the injector goes into. YOU MUST find the remnants of that copper washer and remove them!
