ok heres the prob i did some extensive looking around and well heres the video ill let this start me off.... Video of 2001 F-250 Truck Prob - Photobucket - Video and Image Hosting
ok what u just saw was my 2001 F250 act like it has a hard time starting.... heres the situation wheather temp high 53 low 40's not plugged in to show u what i ran into one day in the woods hunting (an ohh crap situation) heres what happened leading up to this i posted a lil subject called "WORRIED!!!! edge J&A programing prob" in general discussion... Quote:
and a short ABS light till i moved the truck .... so im trying to sort out if a programing error happened when i unlpuged the truck WHILE it was in "tow" mode or if im in for some glow plug sorting out one of these weekends. but what real gets me is the stero shutting off, before the vid it did it just once but now its doing it twice!!! what in the world
ohh and what bothers me or dumbfounds me
the most is what sounds like relays or something clicking real bad when starting m assumeing the relays for the glow plug??? i have never had the glow plug probs and never seen them described when they go bad other then testing them. so im just getting general knowledge before i dive into this project with the only company truck and days of down time troubeshooting
Sounds like a glow plug relay to me, but not sure. Here's a bump for ya.
You will get the KAM error whenever you disconnect the batteries was it P0603 that happens when you change tunes also
It sounded like a relay was clicking i could not tell if the truck was turning over in you vid? I would start by rechecking your battery and starter connections make sure they are tight Last edited by Dave; 11-13-2007 at 06:01 AM. |
well heres the update after i hunted this morn and sat in the blind all morn i started to do the process of elimination in my head by running down what could be going on. so i checked all the important fusesto the relays, the fuel pumps, pcm, glow plugs and so on. there all good and i noticed after pulling the first fuse.... i solved the radio problem with it shuting on and off on start up (weird
) and yea the truck would turn over in the vid... i tried to start it this morn since i had to move it... nope wasnt happening the darn GFI out let tripped last night and the engine was only 50 degress and it would not fire i almost drained the batt. about to get ready to try starting to night ill post back if i have any luck. |
If you're having trouble starting UNLESS you have it plugged in, I'd seriously start to look at the electrical circuit to the glow plugs...
ight will do just tried starting 92 degress oil temp and so on... nothing so iv got to look around here somewhere and find my haynes book to see where the relays are.. txs guys ill let u know what i find so if any one else ever has this prob it will be an easy fix for anyone else.
Have your batteries checked and clean the battery terminals. The relay clicking is caused by low power while cranking. If that is not your problem then go to the glow plugs. PSD's take a alot of battery to start in the winter. First you have your glowplugs drawing alot of power (they are still on even after the WTS light goes out and while your cranking), then your starter is pulling drawing alot turning over 444 cu in at very high compression ratio and the oil is cold and many other factors. So You need 2 good batteries for a PSD to start well when it starts to get cold out.
Bump might have same prob but mine starts most of the time.
ok todays progress.... went out tried to start it again no luck so i rolled up the sleves and started proccess of elimination.
Now first off in theroy if one glow plug went bad is there a chance the rest would atleast try to start the truck?? second i tested the voltage to the relays and checked for the clicks. but by my self i think i only heard one activate and a real faint moan...... both relays had about 10.35 volts running throught and yea i know batts are low chargeing them right now.... third thing i checked i was the lead off the starter soilniod its still firm and anchered securely and cleanly to the terminal... so im at a stand still till i can get some one else to trun the ignition on and see if i can hear 1 or 2 clciks with the glow plug relays... any other ideas please let me know ohhh and yes i have called edge and they claim with the juice and attitude it should not have an effect on it being at lvl 2 and unpluging batts... yet if i had my evolution programed i would be crewed if this is PCM or any other electrical prob related Last edited by LilGuy21585; 11-14-2007 at 08:19 AM. |
