Help! No start, no buzz - Ford Powerstroke Diesel Forum
Old 01-12-2013, 09:39 AM
I'm working on a customers truck. Did an egr delete on it. Got it all back together and all it would do is crank. Good icp ect... No injector buzz. I had no ficm v until I started wiggling wires around on the injector harness. Then the injectors would start buzzing. After a ton of cranking and dieing it started. Went and drove it had a huge miss. The whole truck would shake when you lug it. And no power. Shut it off back at the shop. It started right up again. This morning. All it will do is crank. Have 48v ficm v but no buzz.? Help!!!
Sent from my iPhone using AutoGuide.com Free App
Old 01-12-2013, 02:03 PM
Got it to start. Ram great for 20 sec then just shut off. Now no injector buzz again
Old 01-12-2013, 02:21 PM
MAD - Modification Addict
Feedback Score: 8 reviews
Sounds like either your FICM harness(es) might be either loose or the logic side of the FICM took a dump on you. Try playing with the harnesses and if that doesn't work than swap the FICM with a known good complete FICM and see if it buzzes and starts.
Old 01-13-2013, 12:38 PM
Swapped another ficm into it. Fired right up.
Old 01-13-2013, 12:44 PM
Well there you go.
Old 01-13-2013, 06:45 PM
its strange. that it would go out right after doing an egr delete. it ran horrible when it was dropped off. but ficm checked out good. pulled the ficm apart and soldered it. got it to start but ran horrible. oh well. new one should be in tomorrow
Old 01-13-2013, 07:38 PM
Oh and after I soldered it my modis was saying ficm output v was like 132v lol
Old 01-13-2013, 07:48 PM
Yeah that's no bueno. Lol.
Old 01-15-2013, 06:19 AM
Advanced auto gave me half the board. It fired right up twice after installation. Now no injector buzz again and no start
Old 01-15-2013, 09:18 AM
Take it back and buy a full ficm from your local international dealer.
