7.3 misses during rain - Ford Powerstroke Diesel Forum
Old 07-27-2006, 03:02 PM
Hi, I have an issue that sounds like a cps, but only happens when it's raining.
Three different rain storms now have caused my PSD to shut off and back on while driving. It's like the light switch being turned off and back on in less than a second causing on heck of jolt.
I have read everyones post, but have failed to see if anyone else is affected by weather. When the weather is clear I have no issues, but even a light rain that dose'nt soak the road will cause this event.
Of course there is no trouble light/check engine just one big jolt!!!
Can't be good on the drivetrain. Ford wants $185.00 to run a test on it, but I wanted to see what you guys and gals thought.
Thanks! Lancer
Old 07-27-2006, 04:12 PM
have you tried to pull codes just for kicks?? It doesnt have to have a CEL on to have codes stored.....also, what year is your truck??
Old 07-27-2006, 04:25 PM
Thanks for reminding me!!! It's a 2002 Excursion.
As far as checking codes I see that Autozone does this for free! Is that right??
Hey Mark great site !!!
Thanks!
Lancer
Old 07-27-2006, 04:31 PM
Yup, autozone will scan for free.....the other think we might need to do is pull the IDM out and see if its getting water up in there.....maybe fill the sockets with di electric grease if it looks like it is.....see whats there for codes first and we will go from there..
Old 09-22-2007, 11:48 AM
exact problems
hey i just posted a thread describing identical problems. I already tried to seal my IDM and then it cut off in the next rain and threw a cam sensor code. Replaced the cam sensor now it just cuts off and sometimes thorws a cam sensor code, other times i get nothing please let me know if you figure something out. I'M DESPERATE!
Old 12-11-2007, 10:30 AM
Unhappy exact problem
I have the same problem. When I run in light Rain, The engine just cuts out for a second than continues just fine for a while. Have also had it just die out at a stop, restarts like normal start.
Anybody find a solution? My Ford dealer has never heard of this and either has another PowerStroke mechanic herard of this.
Old 12-11-2007, 10:49 AM
KVFD
its the cps my bosses 02 did that i replaced it for him and it cured it there is a recall coming out on december 17 for the cps heres a link:
Ford recalls 1.1 million vehicles - Yahoo! News
Old 12-11-2007, 11:03 AM
Thanks for your help and the quick reply.
Have you seen this happen when pulling a trailer. When I pulled my 4K LBS. trailer last time (before my transmission went out), when I came to a stop or slowed to exit the hiway, the engine died and left me no power steering and little brakes, have to throw it in neutral and restart it.
The engine started right up.
George
Old 12-12-2007, 08:49 AM
i have the same problem i sealed up all the connectors that i could the cps is new and still stalling let me know what you came up with. I AVE A 99 7.3 F 250 POWER STROKE
Old 12-12-2007, 08:53 AM
I am going to try the recall and clean the connectors to the computer.
I will let you know.
