7.3 Random miss/studder - Ford Powerstroke Diesel Forum
Old 10-30-2007, 07:03 AM
Hello,
I have a 2000 f-250, 97K miles with the 7.3 and and auto with . Here is the situation I will be driving on the freeway at about 65 with the cruise set and all of the sudden it will start chugging ans the SES light will blink on and off a couple times. As soon as I give is a little throttle and let it come back down its fine.
Any Ideas? I just picked the truck up so I have no idea when the last time the fuel filter, oil and other were changed.
Thanks in advance
Terry
Old 10-31-2007, 04:07 PM
Still having the same problem. I replaced the Cam position sensor with one I bought at NAPA, new fuel filter no change at all. I hooked up the scanner and no code either. It is getting a little worse everytime I drive it any have any ideas?????????
Old 11-01-2007, 09:21 AM
No one has anything??????
Old 11-02-2007, 05:12 PM
Took it to the dealership so they can fix it because I am stumped........
Old 11-02-2007, 05:28 PM
Desert Shield/Storm Vet
If you have the ses light you have codes.
Old 11-02-2007, 06:45 PM
SES light goes off when problem stops and stores no codes, even hooked scanner up to it while it was doing it and no codes.
Old 11-03-2007, 05:55 AM
What kind of scanner are you using? Most of the cheaper ones won't pick up codes on a diesel. Do you have a buddy that has a tuner as they will pick up most codes.
Old 11-03-2007, 06:42 AM
If I remeber correctly its and Autotap
Old 11-03-2007, 06:47 AM
check the valve cover gaskets. they have the connectors for the injectors in the gasket. my tech said that the clips that hold the connector inside the valve cover with melt over time and cause it to fall out of the gasket. When my old truck did that, i looked at my egt and it only said like 90* and i had a buddy wiggle the connectors that got to the valve cover and it stopped running rough and egt came back up to around 190* just my .02
