bad coolant leak - Ford Powerstroke Diesel Forum
Old 12-14-2012, 02:15 PM
bad coolant leak
Guys I need some help bad. I have a bad coolant leak from passenger side wheel well. Thought it was Egr cooler or head gasket but now im not sure. After I did new injectors I would sometimes get white smoke until truck was warm. On my way home one day truck got hot put 2 gallons in and drove 6 miles home. Next morning degas bottle empty. Put a gallon in and drove 10 miles to work. Parked and could just watch it drip from bottom of wheel well for a long time. After finding no evidence of leaking on motor pulled glow plugs for possible hydrolock. Not much came out mostly if not all oil. Then I notice I forgot to plug in a little gray hose to my heater control valve after injectorI replacement Been driving like that for a week. Could that be my culprit. Top of the wheel well shows white coolant residue. Got some pics of everything I too if that will help.
Its a 04 6.0 f250
Old 12-14-2012, 03:02 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Did you check the hose going to the egr cooler?
Old 12-14-2012, 03:08 PM
Ya no leaks that i can see and i have the blue hose.
Old 12-14-2012, 03:28 PM
StIck your hand on it and feel it.
Old 12-14-2012, 03:37 PM
Her is a couple pics
The little grey hose i for got to hook back up.
Egr valve upon removal. Not water wet but sticky gooish
Residue on wheel well cover where coolant leaked and ran to very bottom of cover and dripped.
https://lh4.googleusercontent.com/-B...-31-15_703.jpg
Directly above where residue is?
https://lh3.googleusercontent.com/-m...-34-40_256.jpg
Old 12-14-2012, 03:43 PM
It was dry on top i didnt get to feel all around it tho. I have it partial tore down when I payed more attention and noticed the grey hose and collant residue.
