Gas in my tank
I lent the truck to my wife and she filled it up with gas and it shut of on her...i have drained the tank and cleared the lines....filled with fresh diesel and bleed till i have no air...the truck still wont start...i have soaked a rag with gas and coverd the turbo and it will start for about 5 second @ 500 rpm...i have tried the inertia switch but nothing.. the hpfp has 6 psi on the low side...i have not checked high side or rail psi...does this sound like an injectors or a inj pump...did all this on the side of the road haha
2008 6.4 all stock |
i saw on a fourm that a stuck open egr can cause this??????
OUCH!!!!
This is not good.
we have truck in the shop right now as we type that did the same thing
What have you guys done? same step that i did?
I have an entire exhaust system sitting in front of me, Cats, Muffler and tail pipe, ready to be replaced, Plugged everything up! everything has to be replaced
oh FUUUUUUUUUUUU(k .......how to i find out of those are blocked? i have a modis...can i regenerate the dpf
EVERYTHING is being replaced in this truck! And i mean EVERYTHING
I'd be more worried about the HPFP, injectors and lines since the pump is lubricated by diesel fuel.
