2005 6.0 wont start - Ford Powerstroke Diesel Forum
Old 12-10-2012, 09:41 AM
2005 6.0 wont start
For a year I have been dealing with this problem by not dealing with the problem, and now I have to.
For the last year, the truck would start 95% time, but that 5% it would crank and not fire but ten minutes later it would start, and it would happen when warm and cold. However, it would pop start on the slightest of grade or behind another vehicle. Recently my buddy was using it, killed it at a stop light, and had to get it pop started to make it home. It hasn't started by cranking since , though it has started by pop starting.
a week ago i had to use it and pop started it, and 5 miles later i started loosing power for the last mile, then it shut down. I had my buddy tow me back to town and it would start and die periodically, but then start again. It seemed like it wasn't getting any fuel, so I replaced the fuel filters. We pop started it again, and it fired right up with no effort. After about 20 minutes of idling to get the air out, it was starting to sound like it was running great. I hit the fuel peddle to increase the rpms and it simply died with no throttle response. Hasn't started since even when trying to pop start. Finally got the shop over here to run the codes, and here is what I got.
P0270
P0275
P0278
P0299
P0341
P2285
P2290
P2291
My engine cranks at 140 rpm, but it isn't plugged in and is 20 degrees out. There is oil pressure on the gauge, and IPR gets to 85%.
Cam and FICM are showing synced and the PSI when cranking is 464.
I was going to get down to the FICM and test the voltage, then work my way back to the IPR and pull it (I replaced it a year ago)...
Am i on the right track or does someone have another course of action that would be better.
Thanks in advance,
Noel
Old 12-10-2012, 09:47 AM
Feedback Score: 5 reviews
FICM, Batteries, or HPO leak
The HPO needs to be at a minimum of 500PSI to start. your loosing pressure somewhere
IPR/ or next would be STC fitting, standpipes, Dummy plugs
Old 12-10-2012, 12:31 PM
what are dummy plugs?
Old 12-10-2012, 12:43 PM
Illiana Chapter Director
They are plugs that go into the front of each oil rail.
Old 12-10-2012, 12:46 PM
I'd start by checking FICM voltage while cranking and get that fixed first. After the FICM is up to par, unplug your ICP sensor and see if the truck starts. Also need to check fuel pressure. If it doesn't start then you're gonna have to check the HPO system for a leak.
Old 12-11-2012, 06:28 PM
I got in and checked ficm tonight. 47.8 volts koeo, 47.6 when cranking. Will figure out how to check fuel pressure and then go from there. If it is the hoop, or related, cab up? Not going to like this. I miss my Chevy 6.5 now.
Old 12-11-2012, 06:54 PM
Cab doesn't have to be removed for HPOP issue
