No Power, Lots of Smoke - Ford Powerstroke Diesel Forum
post #1 of 5 Old 11-15-2012, 04:49 PM Thread Starter
2001 Ford F550, will not rev past 1800rpm. At 1800rpm, large amount of smoke and no power. Changed fuel filter... did not help. What do I check next?
bill1958 is offline
post #2 of 5 Old 11-15-2012, 07:29 PM
7.3550Duty's Avatar
check intercooler boots for rips or cracks. if not there, check your up pipes for black soot around the fittings up towards the turbo.
What you running for intake setup?? maybe clogged filter if stock.
Robert
01 F350 CCSB
a few mods
7.3550Duty is offline
post #3 of 5 Old 11-16-2012, 05:07 AM
mxfever090's Avatar
I will bet the EBPV is stuck closed.
EBPV stuck or not working correctly will keep the turbo from spooling. You can still throttle like normal and the ECM fuels accordingly. Since the turbo won't spool and build boost it overfuels causeing excessive smoke.
My truck did this a little over a week ago.
Check this out.
Ebpv plug question pics
Jason
O.T.F.D. Volunteer 19
Great White - 2003 7.3l F-250 4x4 CCSB -102,000 miles and tickin
DIY intake - 4" Straight pipe - HPX - CAT ELC - 203° t stat - billet t stat housing - coolant filter - dual alt radiator hose - 12V Air compressor - 5 gallon air tank - Air line quick connects - AIR HORNS!
Hers: 2013 VW Jetta TDI
mxfever090 is offline
post #4 of 5 Old 11-16-2012, 06:46 PM Thread Starter
to mxfever090
Thank's a million! I unplugged my ebpu and I got my truck and loaded trailer home truck seemed to run fine but do I gut the sensor or replace it and if I gut it what will be different
But thank's again
bill1958 is offline
post #5 of 5 Old 11-20-2012, 05:06 AM
mxfever090's Avatar
Originally Posted by bill1958 View Post
to mxfever090
But thank's again
Your welcome Bill and glad you made it home Pull the EBPV sensor tube and clean it out. There are links to video's here on the site or just search youtube for how to clean 7.3 EBPV sensor tube. You can leave the EBPV unplugged but it will through a soft code. Truthfully next on my list of things to do is to put on a Non-EBPV pedistal because the thing is straight up annoying and my actuator rod is leaking.
Jason
