3/4 tank of gas burned 2004 F250 in Iceland - Ford Powerstroke Diesel Forum
Old 10-26-2007, 01:09 AM
Not me but a fruitcake friend of my wife here in Iceland had his truck filled somehow with gas? He drove it down to 1/4 and then filled it with diesel. He picked us up at the airport (this happen 2 months prior and he spent almost $8000 to keep it running) and the truck seemed to run ok until under a load where he had to let off the accelerator and feather the pedal. I spoke with the mechanic but his english and my Icelandic are way off. I asked if he did a compression test and he said "yes" but we couldn't understand each other. Most of the work performed was on the fuel system and he says he needs something for the #6 cylinder and its not any kind of seal or gasket? I looked online at a few sites and see nothing other than seals. I asked him if it was an injector and he thinks so???? He said the part cost the equivalent of $850 here but from past experience I could buy it in the US for 1/3 the cost or less.... There was diesel all over the motor and the airbox was snapped back together incorrectly so I took the truck home one night to clean it a little and fix some little things these couple different mechanics put back together. When I started the truck cold it was the worse sounding engine I have ever heard including many demolishion derby cars I've ruined. Without any diesel knowledge this sounded like 3 times worse than any main bearing in a gas motor I've ever heard....Last night another backyard mechanic was going to install a fuel pump in the fuel tank (I think or wherever, so much is lost in translation) Do you think this could be a fuel system problem? The motor doesn't sound bad when started warm or running. Because of lack of money I suggested a block heater because although its not so cold here in Reykjavik he lives about 5 miles away and its very cold there overnight.
Old 10-26-2007, 01:29 AM
When of the techs should be awake and or online shortly to help. Until then we will try to keep this on the front page. Sorry I can't help. Other than keeping it visable.
Old 10-26-2007, 01:38 AM
Thanks
Thanks, its almost 10am here but the middle of the night there.
Old 10-26-2007, 01:41 AM
It is 3 AM on the west coast. What are you doing up in Iceland?
Old 10-26-2007, 01:56 AM
good question
My family is from here. This friend was in the market for a heavy duty truck and with the gas/diesel prices at almost $10.00 a gallon I had been driving an Excursion with the 6.0 and I recommended this F250 truck to him.
Old 10-26-2007, 02:02 AM
Almostdunfukinwidit
10 bucks a gallon holy crap
Old 10-26-2007, 02:04 AM
Old 10-26-2007, 02:32 AM
Rob Rob is offline
10 bucks a gallon????? man and i thought we were getting ripped off!!!!
Old 10-26-2007, 02:36 AM
Almostdunfukinwidit
Hopefully there is a big difference in value between our and icelands money. Wow
Old 10-26-2007, 03:19 AM
Our moneys becoming worthless even in Canada
The dollar has fallen to all time lows all over the world. When I first came in 2001 one dollar was worth 122 Icelandic Krona, the other day it was 59 Krona
Last edited by Ekortsrewop; 10-26-2007 at 05:34 AM. Reason: omitting political opinion
