7.3 cranks no start - Ford Powerstroke Diesel Forum
post #1 of 3 Old 11-13-2012, 07:36 AM Thread Starter
7.3 cranks no start
keeps blowing 30a ignition fuse.any idea where to start looking for short?
rtrout64 is offline
post #2 of 3 Old 11-13-2012, 11:09 AM
Quoted: 157 Post(s)
Feedback Score: 3 reviews
Sure. it's actually an easy one
Unplug the Fuel Heater Element in the bottom of the Filter Housing.
Over the Summer, that element has rotted through and only now, with the colder weather, is the PCM turning it on. So, it's blowing the fuse and keeping the PCM itself from powering-up. Replace the fuse (with the heater unplugged) and you should be good-to-go.
MANY people never replace that element and have no trouble at all so, there's no problem if you drive it that way for a while...
NoRalPh is offline
post #3 of 3 Old 11-13-2012, 06:04 PM Thread Starter
7.3 running
thanks for input found out that heater was on same circuit.changed it out[obvious bare wire was showing].was getting nervous going on a 5 day chukar @phe3asant hunt.
rtrout64 is offline
