96 7.3 Wont start! please help
So I have a 96 7.3 f-250 4x4 with 225k on it, Was headed out to go hunting and took my Edge chip off the race mode and turned it back to tow mode for the trip over the mountains. I followed all procedures just as the directions say and like I have done before with no problems. However now my truck will not start.
After doing the chip I went to start it and the motor would just crank over, but the "Wait To Start" light stays on and will not turn off, it ALWAYS turned OFF before, why would my light stay on? I have fuel and fuse #22 is ok, I even replaced it to be sure. What should I start with? I do see the WTS light is kinda blinking and when it does blink I hear a slight clicking under my dash on the drivers side near that fuse panel. Thanks in advance for your help. Also pulled I did not pull any codes. Last edited by skiier47; 11-02-2012 at 09:32 AM. |
try plugging it in. could be your glow plug relay decided to quit.
did you try reprogramming to see if that works? |
if glowplugs are not working the light may stay on
Does your tach bounce when cranking?
