Idle sounds Like I am Gunning throttle - Ford Powerstroke Diesel Forum
Old 10-24-2007, 06:01 AM
Navy Beer Guzzler
My truck has started doing this every morning when I Start it maybe 50 degrees outside. It did this once last year. Now It does it every time. It will gun up to 1100 to 1200 rpms and drop if you dont catch it with throttle I think it will die allthough I havent actually let it die.Does the truck have an idle control module or something that could be bad. Thanks
Mike
Old 10-24-2007, 09:50 AM
Powerstroke Techie
I have a buddy with a 01 that was doing that, I’m not sure if I believe it or not but he swears changing the CPS fixed it. I was guessing at glow plug system or the IPR but he said a Cam sensor solved his.
Old 10-25-2007, 04:45 AM
Navy Beer Guzzler
I got a new one on order they are cheap enough now to just try it anyway. I have been meaning to get a spare one anyway. The only thing is it did this right after replacing cam sensor last year once or twice.
Thanks
Mike
Old 10-25-2007, 05:18 AM
Mike
are you talking about the high idle. my truck will do the is if you let it set for a min while running while its cold out. the truck will got o 1200 rpm to help it stay warm. it will fall back to 600 rpm if you touch the brakes. let it go up its not gonna die unless you have another problem. i would have to say this is normal. it just seems like its gonna die cause you drop from 1200 to 600 rpm which is a big drop. mine does it all the time when its cold out.
Old 10-26-2007, 05:18 AM
Navy Beer Guzzler
No its not the high idle. It keeps doing it over and over again. Just like If I was sitting there gunning throttle up to 1200 rpms and drops over and over again till you gun throttle and sometimes that takes 2 or 3 times to make it stop. I dont get any codes. It also smokes pretty bad with smoke that burns your eyes. I cant tell what color it is I think its white. I just took it to a local diesel mech and he found a bad glo plug relay. It was bad checked myself but it hasnt been giving me a hard time starting so did not notice it. Still did not fix the problem. I am sorry so long but some help would be greatly appreciated.
Mike
Old 10-26-2007, 06:28 PM
Navy Beer Guzzler
bump bump bump
Old 10-26-2007, 06:48 PM
so your basically saying it is surging from idle to 1200 constantly. or just in the morning. can you make a video of it doing or take a pic of the just trying to troubleshoot with ya.
Old 10-27-2007, 05:39 AM
Navy Beer Guzzler
Ok I can make the movie but I will need lots of help to get it on here.
Old 10-27-2007, 05:51 AM
White smoke sounds bad, I can't help you out there but mine idles up to 1200 for a bit when its cold and then goes back down to 600rpms in the morning.
Bump to the top
Old 10-27-2007, 07:04 AM
Navy Beer Guzzler
I am uploading video to myspace I will need directions to link from here to it I will try and upload this evening. i obviously am not explaining very well. It almost seems like tps but what i am hoping for is someone who has ahd this problem before to say they know what it is. So if i could get linking directions from someone it would be a gret help.
