2000 7.3 new injectors now no power and smoke - Ford Powerstroke Diesel Forum
Old 10-13-2012, 04:02 PM
just installed reman injectors and now no power and lots of smoke pulled them back out today to double check o rings and copper all good and made sure all of them were seated down good. wtf is going on??? at least my cold start is sloved but cant drive it like this anyone have a fix for this???
Old 10-16-2012, 05:46 AM
did you suck all the oil out of the cylinders after you changed the injectors? You can use a simple vaccuum brake bleeder and a hose to pull the oil from the cylinders. Maybe it has too much oil in the cylinders to fire good.
Old 10-16-2012, 05:58 AM
Where did you get them?
I put remans in mine and 4 of them were crap in less than 500 miles.
Old 10-19-2012, 04:59 PM
They were Pensacola diesel. Pulled them again and it was carbon build up in the ports. Cleaned it out real good re-installed and got power back. Still smokes once in a while after warm for about 10 min. Then goes away guessing its blow by comming in gotta do the Pcv delete but for you hard start guys injectors made all the difference. I've been plugging this thing in for 4 yrs but not anymore
