Leaving work yesterday and everythings great. About 5 minutes i had been driving and i acelerate a little bit on an incline. After im over the peak i got to get back on the gas somewhat and it's starts coughin and ****tin on me. Im down to about 35mph at this point and around 900rpm just barely cruising. I got to accelerate a little more i just eased into it and right above 2,000rpm she just shakes and baxks me back down. I was also watching my psi, wouldnt get passed 10lbs. So i cruised her home tho whole way at about 35 because she was running perfectly fine under 2,000rpm. Parked her and she idles fine. Starts right up fine. And runs fine all the way up to 2,000rpm. I have some different ideas but i know you guys are the wiz's. Please help. Also didn't look but dont think i saw any white smoke.
My bad! Shes basically stock...theres a gibs tip and mid pipe but i havent even fully looked at it. Just bought her a week ago. You think maybe fuel filter is clogged!? Its basically exactly like if a 2-stroke dirtbike carb was clogged. Thanks for helping though!
+1 on monitoring fuel pressure. change the fuel filters and drain the water separator before you drive it much more.
Shop says diagnostic popped 3 egr codes. They said the egr will cause it you think its true? If it is should i just have them put a delete kit on they said that would cost 500$
I think the egr valve will open at higher rpms, so if the egr valve was stuck closed it does make sense that it would cause an issue.
If it's warranty I'd let them fix it and be on your way. If its coming out of your pocket, then an egr delete is the way to go. If you go this route you will also need a tuner that is emissions delete capable. |
Appreciating the help man |
No, you have to have a tuner to run the truck with a deleted egr. If you delete without tuning the truck will throw codes and go into limp mode.
If I were you I'd call any of our site supporting vendors and ask them for a quote on a package deal of egr delete kit, tuner, delete pipe (or full exhaust), and cold air intake. |
Limp mode is bad damnt
