6.0l FROM HELL - Ford Powerstroke Diesel Forum
Old 09-03-2012, 03:10 PM
Angry 6.0l FROM HELL
BUILDING PRESURE IN COOLING?
COOLANT TEMP 180-200 BLOWING OUT OF RESIVOR
NO OIL IN COOLANT OR IN OIL
OIL TEMP 200-230
Old 09-03-2012, 03:25 PM
Egr cooler and or headgaskets
Sent from my iPad using AG Free
Old 09-03-2012, 03:40 PM
I HAVE SINISTER EGR DEL. ON TRUCK NOW
DONT HAVE ANY LOSE IN COMP.
DID HAVE A DTC BUT CLEARED NOT BACK OF #4&8 CONTRIBUTION/BLANCE
Old 09-03-2012, 04:09 PM
6.0 from ****? Sounds like someone needs some maintenance along with knowledge first.
That is a high ECT/EOT delta. Oil cooler possibly.
How high is the coolant level when cold in the degass bottle? About 1/4" below min is new max.
Old 09-03-2012, 05:13 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Oil cooler will NOT cause puking. Cracked EGR cooler or blown head gaskets will. A cracked oil cooler will leak oil into the cooling system.
If you have an EGR delete your looking at a head gasket job. Get ready.
Old 09-04-2012, 02:32 AM
I've been haveing problems this truck since bought used last nov. has 210, on it now
open for sugestion/ advice on what to do.
1. Should I do head gasket job with a solution kit
2. Find used motor up grade it befoe install
3. Buy crate motor all ready done up
Thank you
Old 09-04-2012, 03:17 AM
I made my own kit with River City Diesel they we're great and gave a good discount since I bought everything from them
Check them out
Old 09-04-2012, 04:34 AM
I would have said EGR and oil cooler. If EGR Delete is good, have heads checked for cracks when you do the gaskets.
Old 09-04-2012, 04:42 AM
Truck took all my money
do an EGR delete and more than likely you will be doing head studs...
EDIT: and with oil temps reaching 230 replace the oil cooler while your in there.
Old 09-04-2012, 06:21 AM
oil cooler was first thing went out on truck cost me $3,200.00 @ ford house done in jan. this yr. I aready put to many miles since for it to be coverd by waranty and egr went out in april installed delete my self . I've just orderd a complete solution kit sinister thanks for advice
