2000 7.3 wont start - Ford Powerstroke Diesel Forum
Old 08-27-2012, 06:14 PM
2000 7.3 wont start
Help!! I am stuck in the menards parking lot... no WTS light and fuse #30 is blown. Unplugged fuel heater and wastegate solenoid (I think) still blows the fuse instantly when I turn the key on... what next?
Old 08-27-2012, 06:19 PM
Sure you unplugged the fuel heater on back of the bowl?
Old 08-27-2012, 06:36 PM
I think so... there was 2 plugs there and I unplugged them both just to be sure... it still blows the fuse instantly when turn the key on.. I also pulled the pcm and idm relays and it still blows the fuse
Old 08-27-2012, 06:51 PM
The wife got someone to sit with the kids and she is coming to get me... I guess I will look at it again tomorrow after work... but I am lost on where to start... can I pull codes from the computer if that fuse won't hold?
Old 08-28-2012, 04:06 AM
Something is shorted. Not sure what else it could be. Maybe the wiring harness but it's hard to tell.
You might can pull codes, idk.
Old 08-28-2012, 07:19 AM
maybe you can pull the fuse and check continuity from there to ground. if it has it (likely) with the sensors unplugged, you will have to trace the harness.
Old 08-28-2012, 11:27 AM
Ok... got it fixed, we resorted to the ohm meter and found a short to ground... it turned out that the wiring harness was rubbed thru and was shorting out on the drivers side valve cover ... a little black tape and she is back on the road :-)
Old 08-28-2012, 11:56 AM
glad to hear!!! awesome!!!
