IPR Connector Clock Wrong Direction
I just picked up an IPR sensor from a local parts store. When installing it, the electrical connector faces up, towards the turbo pipe. Is this a problem... or should I put it back together?
You should be able to rotate the connector wherever you need it, mine kinda faces up a about a 2 o'clock position towards the pipe. If the connector will reach as long as wire won't touch anything throw her back together you should be fine
What would I be doing right now if I didn't have an iPhone? |
