egr problems - Ford Powerstroke Diesel Forum
Old 08-03-2012, 08:46 PM
egr problems
I just traded for a 2006 f250 powerstroke. Of course all kinds of egr codes. I've thought about a egr delete but man it is alot of work. Could I just not get like a sct sf3 tuner and turn off egr and tack weld egr valve to stay closed?
Old 08-04-2012, 04:38 AM
Should have dealt with the codes before you agreed to the trade. Tack welding the EGR valve doesn't protect you if the EGR cooler starts leaking. Also, if you have a bunch of codes the EGR valve and manifold are probably loaded with soot. Doing a full delete isn't that hard, just a little time consuming. If my teenage son can do it on his uncles truck you can do it on your own truck. LOL
Sent from my Autoguide iPad app
