How screwed am I!? - Ford Powerstroke Diesel Forum
Old 08-02-2012, 03:35 PM
How screwed am I!?
Okay so after I got done replacing my stand pipes and dummy plugs I took the truck out for a quick spin and as I was coming back up the hill my radiator hose on the passenger side came off and for about half a mile I lost all my coolant, the fan kicked on and I shut the truck off ASAP, it was still coming out of the hose after it was off till it all was gone, is anything going to be hurt!?
Old 08-02-2012, 03:44 PM
Chapter Director
Send a message via AIM to Fantom
As long as you shut it down right away, you should be fine.
Old 08-02-2012, 03:47 PM
285,261,190
X2.........
Old 08-02-2012, 03:49 PM
Okay that's what I figured, the temp gauge didn't even budge and I didn't throw any codes
Old 08-02-2012, 03:50 PM
Chapter Director
Nah, don't sweat it. Tighten up the clamp, fill it up with coolant and drive that beast.
Old 08-02-2012, 03:51 PM
MAD - Modification Addict
Feedback Score: 7 reviews
Yeah you should be alright as long as you didn't continue to run the truck after all the coolant drained. Did you get your stc fitting and everything done on it now?
Old 08-02-2012, 04:14 PM
Not yet lol I get my two drives a day out of her
Old 08-02-2012, 04:20 PM
LOL I know what you mean hahaha it sucks.
Old 08-02-2012, 04:31 PM
I got the STI to keep me busy lol
Old 08-02-2012, 05:00 PM
Guns & Powerstroke's
Bad thing with temp gauges is you have to have a medium for them to measure in this case water. If it drains quickly like in your case the sensor is not immersed and will no longer work correctly cause the air around it allows to much heat to be pulled away from the sensor. Good heads up on what happened and getting it shut down.
