01 7,3 finally quit today - Ford Powerstroke Diesel Forum
post #1 of 18 Old 07-28-2012, 09:57 AM Thread Starter
drummondracing's Avatar
Hopefully somonene can help.. Here is a quick rundown. 01 7.3 with 210,000 miles. I have owned the truck for 4 years during which it has ALWAYS been a bit#h to start sometimes. I have to watch the oil press gauge as if it does not jump right up I have to race the motor keep it running.if the gauge does not come up its a crank fest to start,, usually it jumps up and starts....some days it comes up quicker than others...some days I catch it just in time then it the engine will miss for a couple of miles then clear up. I have gotten used to this routnene.Today she fired and went down the road I stopped for breakfast then when I went to start crank crank crank... its NEVER done this Usually after the first start of the day she is good. I cranked forever and finally the gauge came up and she fired. ran fine for a few miles but at a stop sign I noticed it was internmitenly missing and the tach was jumping...any how I shut her off at work. went to restart she ran for 2 seconds the gauge dropped and thats where she quit.... I cranked again forever and ever and the gauge came up but it STILL wouldnt fire..Oil only has about 3 k miles on it so I dont think its thin I use rotella, lucas and a NAPA filter. Im leaning to wards HPOP or injectors....It has never died or stalled always just been a PITA to start but its never done this. HELP!!!!!!!
drummondracing is offline
post #2 of 18 Old 07-28-2012, 10:52 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Not creating low pressure oil pressure is LPOP or pickup maybe.
I made my Samsung SGH-I997 send this.
4R100, 2wd
330,000 + miles
jesilvas is offline
post #3 of 18 Old 07-28-2012, 04:42 PM
Powerstroke Techie
Quoted: 474 Post(s)
start by scanning the vehicle for codes. you'll need access to a scan tool capable of reading manufacturer specific codes. datalogging capabilities as well. the problem may have nothing to do with oil pressure
the richest ones are not those who have the most, but those who need the least
**i don't use capitals. deal with it**
kaya is offline
post #4 of 18 Old 07-29-2012, 04:18 PM Thread Starter
here is what I have found so far...no scan tool available yet. The fuel pump and wait to start light only come on once in every 10 or so key cycles..when they do the wts light flickers fast and I can hear a relay or the glow plug timer clicking like crazy....still no start though...at first I had no fuel pump at all then I checked the rollover switch ..it was tripped why I dont know? I reset it and the fuel pump came on once or twice but along with the dash lights flickering....
post #5 of 18 Old 07-29-2012, 04:21 PM Thread Starter
ok 1 minute later truck fired right up ran perfect for 15 seconds and promply died.. I cycled the key..no fuel pump or wts light again....
post #6 of 18 Old 07-29-2012, 04:26 PM Thread Starter
just rechecked it popped the rollover valve again...I reset it and the truck fired up again for anouther 15 seconds. check light flashed and she died.. looks like its scan tool time.
post #7 of 18 Old 07-30-2012, 11:40 AM
jesilvas's Avatar
Quoted: 3 Post(s)
Do you have a chip installed
4R100, 2wd
330,000 + miles
jesilvas is offline
post #8 of 18 Old 07-30-2012, 11:55 AM Thread Starter
Yeah it has a superchips program
Sent from my SCH-I405 using AutoGuide.Com Free App
post #9 of 18 Old 07-30-2012, 06:03 PM Thread Starter
Well l took The cover off to check The fuses under The dash And did a good ole Ford wiggle test And its running like a top...damn if l know
post #10 of 18 Old 07-30-2012, 06:13 PM
Guns & Powerstroke's
HillClimber350's Avatar
Sounds like your PCM is losing power. Replace the relay to the PCM or swap with the ac blower relay under the hood see if that helps
2001 F-250 Platinum Edition
BTS Trans, 6.0L Cooler, DP Tuner, AFE Stage 2 Intake, 4" turbo back, Bean's 1.0 housing, A/C mod, Billet T-Stat Housing with 203* T-Stat
HillClimber350 is offline
