Truck stolen - Need to shut off
Truck was stolen and was retrieved in under 7hrs. Ignition was broken into and the truck is still running as we speak. What is the eaisiest way to shut off her. Thank you much appreciated!
Only thing I can think of is to pull the fuse for the fuel pump, but you may have some trouble restarting (air in the lines).
Get a clipboard or a piece of wood and stick it over the intake and block the air, should shut right off without putting air in the lines
I took out the fuse and it finally shut off. took of batt. cable so they wouldnt drain cuz dash light on. Thank you guys I appreciate the help. Had $20,000 worth of lawn equipment stolen from truck and trailer. I can't believe the theives had the b*lls to roll the truck out in neutral when it sits right next to my bedroom window. Good luck and take car.
