cooling problem please help - Ford Powerstroke Diesel Forum
Old 07-18-2012, 01:59 PM
Question cooling problem please help
2002 250 7.3 i have replaced the radiator and the water pump and the the thermostat and the coolant resivour and something is causing it to leak coolant either through the resevoir cap or the radiator where the plastic meets the aluminum im stumped my only thoughts are there is a bubble in the system causing problems any ideas
Tags
coolant, cooling system, leaking, radiator
