Changed 7.3 oil pump gasket? Now can't start?
Hey guys
I have just changed oils pump gasket as it was leaking now it's wont start. Just keeps cranking over not starting I need to bleed injector line to grt oil pressure to work injectors? How do you do that? Any help would be grateful! Thanks ben |
unplug the 42 pin connector, and crank the truck for 20 sec. intervals, with 2 mins in between for about 10 mins, then plug the harness back in and crank , she should start.
p.s. put a battery charger on while u are doing this so u don't kill the truck |
Did you fill the oil reservoir? (Assumung it was the hpop oil seal)
Did you evet find the issue?
