yet another 7.3L that just wont crank
I've got a 2000 F350 PowerStroke, and the truck no longer cranks. Its got new batteries, and a new starter solenoid. I can cross the posts on the solenoid and the truck cranks and starts, but without doing that it just doesn't crank, the starter doesn't even sound like it clicks. the wait to start light comes on and goes off like its supposed to, door chimes work, just doesn't crank. once the solenoid posts are crossed that the truck starts it runs just fine. I pulled all the fuses and checked them and none are blown, relay clicks when you try to start the truck, just no starter action.
what should i check next? |
Im having the same problem on my 2000 F250 7.3L. Nothing happens, only some clicking sounds from one of the relays in the fuse box inside the cab. I checked everything, starter, starter relay, alternator, batteris, ignition swith. Everything working fine. I got a P0603 code but that does necessarily mean that I have to replace th PCM, that code comes up when you unplug the batteries for a while. I'm trying to avoid having it sent to a dealership where they are going to send a lot of time trying to figure it out and a lot of my money in the process. Let me know if you find out anything.
Just a suggestion. |
I dont have anything immediately to test that with. but I grapsing at straws now. I'm thinking that it may be the glow plug relay that is right next to the fuel filter. BTW dont waste you time with Autozone, Oreilly's and Advance auto are all stomped by my problem. They will only sell you parts until you get lucky and replace the right one. Been there, done that, still stuck. Waiting to hear back from one of the techs from Tommy Vaungh Ford to call me back. I will post anythig I hear
i got it to start, I'm thinking that somehow it may have been a ground issue, I put a new solenoid on there, and got no juice to the starter switch wire, and when i removed the new solenoid and put the old one back on after scratching a little paint off where it mounts to the fender it started right up ... not sure if it will act up again, but i think it was just being a PITA for the day ...
i might try the same thing. i still have the old one. Tech from TVF was a waste of a phone call. The only thing he was able to help me with was the number of the towing service they use to have my truck taken there. Not going to happen. I'll try what you did and hope for the best. thanks
that work for you Gutierrez333? or you still stuck?
