7.3L white smoke, almost total loss of power, heavy vibration
Cruising down the highway and truck just lost almost all power and started vibrating pretty violently. Pulled over and let it idle, was idling a little rough and was blowing white smoke. Barely limped it to a local garage. Ran an injector buzz test and everything came back normal so it isn't the UVCH. Pulled the codes and got a p1280 and p0470. I know p1280 is ICP sensor could that be the only problem? truck can't even get out of its own way.
Unplug the ICP, setting the PCM to run a default value. If it idles better, then that's probably it.
Unplugged icp, no change at all, any ideas?
Sent from my DROID RAZR using AutoGuide.com App |
Didn't let it get hot and melt a piston did you? That would be my thought. If it's vibrating really bad like a miss, but the injectors are ticking, you've got a compression problem somewhere.
Could be bad fuel as well.
I don't think so no, the EGTs were below 1000 when it happened
my 7.3 did that and it ended up bing valve conections and a error in my programmer
Checked fuel today, it is good, any other ideas?
