wont start - Ford Powerstroke Diesel Forum
Old 06-25-2012, 02:56 PM
wont start
i have a 2003 ford f-350 6.0 liter 4x4 truck died and will not start turns over fine i have a bullydog tridog programmer installed on vehicle i need help on were to start on seeking out the problem
Old 06-25-2012, 03:07 PM
I don't know much but maybe check your ficm voltage.... Check your icp at crank and your ipr... ? Someone who knows more will prob chime in
Old 06-25-2012, 03:11 PM
Maybe try unplugging your icp and cranking it.... If it starts then there is your prob
Old 06-25-2012, 03:16 PM
not a mechanic but i work on all my own vehicles once i know the problem i can fix it but the abbreviations im not following...sorry a 6.0 noob
Old 06-25-2012, 03:19 PM
icp = injection control pressure sensor?
Old 06-25-2012, 03:39 PM
Fuel injection control module
Injection control pressure
Injection pressure regulator
Idk if it's different on your year but the icp sensor on my 06 is on the passenger side valve cover it's a 3 pin connector with a metal type cover looks kinda like an acorn head
I think it's may be on the backside below the turbo which isn't gonna be the easiest to get to
Old 06-26-2012, 03:54 PM
If you have a bad high pressure oil pump, your truck will turn over all day but it won't get any fuel so it won't start.
