Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 07-12-2006, 08:47 AM
bubwebb bubwebb is offline
Exclamation Starts hard in the morn
Replaced IDM and ran scanner got 0476 replacing EBP sensor and what is exh pressure control perform (p0476)Please help guys thanks
Old 07-12-2006, 09:02 AM
trhland trhland is offline
Send a message via AIM to trhland
what engine
what engine?
Old 07-12-2006, 09:04 AM
It is a 2000 7.3
Old 07-12-2006, 09:06 AM
check glow plug relay
i had the same problem in my 2002 .it was the glow plug relay. is it only hard starting when it sits? mine was the same way but allday after that it was fine
Old 07-12-2006, 09:13 AM
Thank im working on it now you say it is a relay not a solenoid ill go look to see if the relay test ok thank you
Old 07-12-2006, 09:19 AM
hope thats the problem if not ask mark .he should help ya out.hes a ford tech.
Old 07-12-2006, 09:21 AM
Relay and solenoids are good
How do i get ahold of Mark
Old 07-12-2006, 09:32 AM
go to member list click that and scroll to the name mark. there might be a couple marks on there but hes the one that says administrater .
Old 07-12-2006, 09:34 AM
it says admim tech supporter click that and youll pull up page hes always on line
Old 07-12-2006, 09:49 AM
thank you i found him but he is offline right now ill keep checking thanks
