White smoke - Ford Powerstroke Diesel Forum
Old 06-19-2012, 04:55 AM
White smoke
So I have white smoke only through 1 and 2nd gear what are some of the cause for this the truck is stock besides my stacks
Sent from my ADR6350 using AutoGuide.Com Free App
Old 06-19-2012, 02:49 PM
Check your coolant level to see how much you are using. It's probably the EGR Cooler leaking.
Old 07-10-2012, 07:46 AM
well after looking into it more i took all my intake tubing off and found some shaft play in my turbo and after watching the smoke ill say its gray and not white but i did notice that my coolant level isn't super low its about 1/2 inch below the min and i have been keeping an eye on it so my game plan is to buy the ipr gen 2 egr delete and do a flush on the truck and look for a turbo rebuild kit is that a good start.
Old 07-10-2012, 06:30 PM
Bump
Old 07-10-2012, 06:36 PM
First question is whether or not you have a monitoring system? You will see that about half the people on here that have smoke issues is because of their injectors or FICM. I have been the victim of each of these culprits.
Old 07-10-2012, 07:03 PM
No I don't have a edge Cts
Old 07-11-2012, 09:10 AM
Here's an example of what two bad injectors looks like. When I was trying to diagnose the issue, everyone guaranteed me it was coolant via a bad EGR. Three years later my FICM went bad and had the same indicators. Also, you NEED a monitoring system ASAFP just so you can keep tabs on stuff like this and your oil cooler. You don't need an Edhe... a Scangauage II works nearly as well ( not as sexy as the CTS) and it costs $160 but is worth its weight in gold. My $.02
Old 07-11-2012, 09:14 AM
Does it only do it when the truck gets warm
Old 07-11-2012, 03:40 PM
It doesn't do it at all anymore. With injectors, it does it whether it's warm or cold. With the FICM, it tends to only do it when the oil is cold.
