white smoke - Ford Powerstroke Diesel Forum
Old 06-14-2012, 06:08 PM
white smoke
I just bought a 2005 one ton and when I first start it up there is alot of coming from the turbo and then there is white smoke when i first take off and a its only when I push on the throttle is my turbo going out?
Old 06-14-2012, 09:46 PM
coming from the actual turbo?? if stuff is coming out of the turbo it sounds like a leak. and as far as the white smoke i'd suspect an egr issue. slow to respond, fairly common. but are you a hundred percent sure this is white smoke?
Old 06-15-2012, 08:11 PM
one hundred on the white smoke and it has a delete kit on it and the turbo noise aint metal on metal more like a leak. would a rebuild kit fix that?
Old 06-15-2012, 08:14 PM
I'm so confused.
You say coming from the turbo. As in out of the turbo housings and leaking into the engine bay?
What is in your tailpipe? Soot, diesel, coolant? Smells like?
What is "one hundred on the white smoke?"
What is "delete kit?" There's many different deletes.
Old 06-15-2012, 08:42 PM
turbo is usually a black smoke issue not a white smoke issue. white smoke is usually undercontributing injectors or coolant going through the combustion process. but yes not enough information. especially the smoke coming from the turbo part.
Old 06-17-2012, 07:12 AM
it has a rcd delete kit on it there is black soot in the tail pipe and the white smoke out of the tail pipe i was told i have a gasket out on my turbo
Old 06-17-2012, 10:08 AM
Originally Posted by jesilvas View Post
I'm so confused.
Still, in red.
What does it smell like and what is deleted?
You can pull off your intake after the turbo and if it's coated in oil, it could be a turbo seal. But it'd be a ton of oil.
If there's a ton of oil coming out of the tailpipe, it could be a turbo seal.
Other than that, it's not a turbo seal.
Old 06-17-2012, 11:36 AM
i took my exhuast apart right after the turbo and there is alot of oil and there really is no smell at my tip of exhaust and the delete kit got rid of the egr vavle
Old 06-17-2012, 11:38 AM
If there's a ton of oil right after the turbo and on the exhaust wheel, sounds like a turbo seal then.
Old 06-17-2012, 11:42 AM
