96 7.3 losing prime - Ford Powerstroke Diesel Forum
Old 06-05-2012, 07:31 PM
96 7.3 losing prime
Truck runs great until it sits all day or over night. Is there a check valve in the fuel bowl? I have replaced the feed and return lines even the ones on the engine. It doesn't seem to be leaking anywhere it just drains the bowl any help or thoughts would be great thanks.
Old 06-06-2012, 05:42 AM
Could it be draining to the tube on the pass side of the motor (over the top of the ft tire, against the motor) that's the "dump" for the water drain valve?
Old 06-06-2012, 01:28 PM
no its not running out the drain you cant see it leaking anywhere. It runs great once you bleed it out.
Old 06-06-2012, 05:04 PM
anybody think of anything that would cause it to bleed off
Old 06-06-2012, 05:14 PM
How is your fuel pressure regulator? Ever rebuilt it?
Old 06-06-2012, 05:19 PM
Hillbilly Deluxe
Feedback Score: 3 reviews
Also when you had the lines off did you happen to clean the fpr screen?? There is a ball check behind the screen that could fall out which would cause this issue...
Sent from my Galaxy S2 while my wife is yelling at me for being on my phone...
Old 06-06-2012, 05:27 PM
so there is a check in the fuel bowl and no I didn't clean it.
Old 06-06-2012, 05:35 PM
In the fuel pressure regulator.
Fuel Pressure Regulator (FPR) Screen Writeup
Old 06-06-2012, 05:45 PM
also it looks like the adrenaline pump I just put in is leaking
Old 06-06-2012, 05:52 PM
what about just deleting the fuel bowl with a spin on filter and a fpr.
