Temp gauge
05 E350 6.0 temp gauge not reading and fan stays on constantly!! Help
if no scan tool, unplug sensor, hook it up to a digital volt/ohm meter and test resistance, OL/open means its bad, cold water/hot water should make the reading change. so unplug engine cold/hot if the sensor seems to be working, test the harness, youll need the pin outs, and youll be testing at the ECM, un plug the connector @the ecm, and check resistance from plug wire to plug wire, should be as close to zero (.01/.02 ohms) anything different and you have a harness issue Last edited by WaOBSPS; 05-23-2012 at 05:21 AM. |
And don't tell anybody you are gutting a cat, FEDS will eat you alive, 100G fine. All about the money, keep it to yourself.
I have no idea what you are talking about
See no evil, hear no evil................
