6.0 engine whistle and whine - Ford Powerstroke Diesel Forum
Old 05-21-2012, 08:17 AM
Leaving for a trip this weekend and need to tow my car. I brought it in to my mechanic and he said the sound I was hearing was it was in need of the bullet proof EGR . 2500 bucks later it is still doing the same thing. It only happens going up a large hill under full power with a 9000lb trailer. No difference in temps on any of the gauges. No other real symptoms. Any thoughts ? Thanks.
Last edited by good hands; 05-22-2012 at 06:18 AM. Reason: EGR no deleted Billet proof installed
Old 05-21-2012, 03:26 PM
Sounds like you might have a torn CAC tube boot or maybe even a cracked intercooler
Old 05-21-2012, 03:34 PM
Is there any noticeable loss of power during this? What year truck?
Old 05-21-2012, 03:42 PM
2006. Yes it really struggles going up a hill.
Old 05-21-2012, 04:15 PM
This is off topic but 2500 for egr delete is crazy!
Old 05-21-2012, 04:30 PM
My mistake. It is the bullet proof egr not the delete. oil cooler was changed, Seals, screens and o rings changed, EGR passages cleaned. oil change and lube done too.
Still sound ridiculous ?
This is my first diesel truck so I hope I can trust these guys.
Old 05-22-2012, 06:00 AM
Sounds a lot better I just did all mine at one time studs egr etc. Was
1500 labor I supplied my parts that labor is cheap done by a buddy of mine that has his own shop and does it every day
Old 05-22-2012, 06:06 AM
The prior owner did the studs. I also have records that he replaced the EGR under waranty but it was replaced with the same Ford part. Pretty stupid if you ask me.
I am taking my mechanic for a ride today with my trailer on the truck so I can duplicate the noise. Hopefully we'll have an answer. If I didn't know the EGR needed to be replaced anyway at some point I'd be pretty pissed off that I spent that much money to fix this noise only to have it do nothing.
Old 05-22-2012, 06:11 AM
Slacker
Feedback Score: 4 reviews
Sounds like the flex section in either your up-pipe or y-pipe has split. I would also double check your CAC boots and intercooler piping to ensure those are not split or torn.
Old 05-22-2012, 06:19 AM
Boost leak or exhaust leak most likely. I have used an evap emissions smoke machine to find air leaks. Seems to be the fastest way to find boost leaks if thats the issue.
