weird trouble code cant find info on. - Ford Powerstroke Diesel Forum
post #1 of 3 Old 05-12-2012, 05:02 PM Thread Starter
P1000 and U2204. Runs good then like crap. 07 6.0L with altof of new parts. Hole top half of motor was off. please help!
oilfieldtrash6.0 is offline
post #2 of 3 Old 05-13-2012, 04:45 PM Thread Starter
icp valve? ipr valve? or coolant in oil causing problems
post #3 of 3 Old 05-28-2012, 07:53 PM
strokemyego's Avatar
p1000 is a generic code that means monitors have not completed. will set any time codes are cleared. but random misfires are usually injectors dumping. but could be crap stuck in ipr valve screen or icp sensor contaminated. not enough info to diag. is icp pressure fluctuating? are any injectors under contributing on power balance? what is your fuel pressure? what is ipr valve percentage?
strokemyego is offline
