94 powerstroke stopped running no fuel pressure
Heres the story 130,000 miles, injector seals went bad replaced them and the fuel pump at the same time four days ago. Started getting the best mileage of its life and the most power. Today headed out from Arkansas to Amarillo and stopped at the bank and it would not start, one hour later cranked right up. Drove it home and now will not start even after waiting. I have the wait to start light and rpms when cranking, batteries are brand new, oil in hpop is 1/8 inch from the top, fuel is being pumped into the bowel, but there is no pressure from the thing that looks like a valve stem on the side of the filter canister. Any thoughts please?
Ok, I got pressure but still it is not starting. Is there a way to see if fuel is making it to the injectors?
Could be a bad injector pressure regulator or connector to the IPR, mine went out on me this past weekend, the truck would crank perfectly but only start sometimes because the electrical connector was damaged.
Go read my post under Quest for Knowledge for what I found on our 01 F350 7.3. Worth trying, don't cost a thing. Good luck, let us know.
Go read my post A Word of Caution, hope it helps.
