6.0 issues - Ford Powerstroke Diesel Forum
post #1 of 2 Old 04-16-2012, 08:10 AM Thread Starter
6.0 issues
I have an 04 6.0 bought it last year with 99k on it I also purchased an extended warranty thru ford right away it needed an injector I have put 20k on truck now it needs 4 more injectors warranty will not cover anything thinking about doing the injectors (8) also egr delete head studs and oil cooler any suggestions I see a lot of problems on here after doing all that stuff
jkeith126 is offline
post #2 of 2 Old 04-16-2012, 08:17 AM
Quoted: 365 Post(s)
Feedback Score: 5 reviews
My suggestions:
1) GAUGES, GAUGES, GAUGES
2) check coolant and oil Deltas (with gauges lol NOT THE CRAPPY DASH GAUGES!!!)
3) Check FICM Voltage (kills injectors if not 48V or above)
4)EGR Delete
5) depending on #2 MAYBE you need a new oil cooler (not sure yet though)
6) head studs......If you WANT TO or NEED TO.... ( is it puking coolant, white smoke out of the exhuast?
2005 F250 King Ranch Work Truck.
Studded and Deleted
175/30% Injectors from WARREN DIESEL!!
Barder Stage 2 Turbo
Warren Comp Tranny w/ PI TC
Six0~Stroker is offline
