fan blade - Ford Powerstroke Diesel Forum
Old 04-14-2012, 05:28 PM
fan blade
what componets need to be removed for access to that sucker?
Old 04-14-2012, 05:35 PM
Sockets . . .
What kind of truck you got? :
Old 04-14-2012, 05:44 PM
2002 7.3L . took a prop strike and I've got to looking at the logistics of access and was wondering if anyone else had same situation......
Old 04-14-2012, 05:52 PM
Old 04-14-2012, 06:20 PM
Oh, to the fan blade isn't bad.
Pull off the belt. Remove anything on top of the two fan shroud bolts. Degas bottle needs to move outta the way. Then once it's all out of the way and it's loose you need something to hold the water pump pulley in place and a big wrench to loosen the fan. Regular threads, not left hand. And the fan and shroud come up at once.
