6.0 MYSTERY - Ford Powerstroke Diesel Forum
Old 04-13-2012, 06:48 AM
6.0 MYSTERY
Have a 06 F350 6.0. Replaced HPOP because ICP reading wouldn't go over ~260psi. After new HPOP installed pressure was slow to build and never got over 340psi. So tried a new HPOP and same thing. The ICP, IPR, and HPOP have all been replaced and the FICM has been rebuilt and still no start. The truck will start with ether and runs healthy (HPOP ~580psi @ idle). After letting it run for 15+min it will start back up after 10+sec of cranking. Getting no codes on Solus Pro. Getting fuel delivery and fuel filters are new.
Need help solving this mystery.
Old 04-13-2012, 09:18 AM
internal oil leak? have some tanks around and a hydraulic shop near by. anyone ever put a couple thousand psi of air to the oil rail to check for leaks?
Old 04-13-2012, 12:05 PM
I would check the plugs in the oil rail for the injectors. The o-rings on these plugs like to wear and break causing oil pressure leaks.
Old 04-13-2012, 01:53 PM
Going to pull the valve covers next and see if there is a leak at the either of the rails. Will let you know what we find.
Old 04-15-2012, 10:59 PM
have you checked your base oil pressure?
Old 04-16-2012, 04:29 AM
Send a message via AIM to jimmyv13 Send a message via Yahoo to jimmyv13
STC fitting? Stand pipes?
Old 04-16-2012, 04:35 AM
Good idea.
Pretty soon your truck won't start at all, ever again.
Old 04-16-2012, 08:54 AM
It was bad o-rings on the head-to-crankcase tube on the drivers side.
Old 04-16-2012, 09:01 AM
At least it was the east side to change, but....you changed both sides right?
Old 04-16-2012, 09:02 AM
Originally Posted by jesilvas View Post
Good idea.
im sure you know what you are talking about but we ALL know ether isnt good for these trucks but when a truck needs to be ran to complete high pressure diagnosis, aka visuals on the actual leak, you do it.
thanks for the input though man. just a heads up to all, it is cheaper and faster if you have your own shop to just change out all the o-rings on the rail.
also to note guys:
FORD DISCONTINUED the oil rail o-ring kit so you have to buy complete oil tubes with o-rings. 100 bucks our cost. LAME news for the little guys
Tags
6.0, hpop, icp, ipr, no start
