7.3 wont start!!!! - Ford Powerstroke Diesel Forum
post #1 of 3 Old 04-08-2012, 03:21 PM Thread Starter
7.3 wont start!!!!
ok so i have replaced glow plugs, glow plug relay, fuel filter, cps sensor with ford dealer parts and still nothing. the batteries are brand new and oil is fuel.
it turns over but doesnt blow smoke tach doesn't move when trying to start wait to start light is on and stays on check engine light is on and when trying to read codes its pulls up an error no dtc. im stumped could my ecm be bad????
rico_121 is offline
post #2 of 3 Old 04-08-2012, 03:21 PM Thread Starter
haha oops oil is full*
rico_121 is offline
post #3 of 3 Old 04-08-2012, 03:54 PM
Quoted: 175 Post(s)
Feedback Score: 3 reviews
First, what yr is your truck? (some show cranking on the tach, some don't)
Next, here's my No Start checklist.
WTS Light? - do you get it when you first roll-on the key?
Tach Movement? - does the tach needle move up slightly when cranking?
Fuel - pump runs? Fuel refilling filter housing? Tank below 1/4?
Is it cranking fast enough? - it won't even TRY to start if cranking really slowly.
Is your truck "chipped"? If so, remove it as a Test.
(I know you've answered some of that already,,,)
Also, it sounds like you're not using the right kind of scanner, our trucks are NOT strictly OBD-II and those scanner won't work well. You need a professional scanner to know what the problem is. Most everyone here like the AutoEnginuity for personal use, otherwise find a Snap-On, MAC, or Ford scanner to help you.
NoRalPh is offline
