It took a problem for me to post... 08 6.4 350
Okay so it took an engine problem for me to post here..
Upon driving home last night I noticed the turbo would spool up and then drop and spool back up to 2 ie mid way on the factory gauge. I had just pulled in and figured i would take a look at it in the morning. Okay so morning has arrived and I popped the hood to see that the boot from the air box to the engine had popped off. ![]() After wrestling that back on i figured I had solved my issue. So I turned the rig on and and drove it around the parking lot to the highway.. (boost now holds so I'm thinking I'm in good shape). I get onto the highway and give it some gas.. everything seems fine until I get just passed 2k rpm, at which point the rig starts to act like I am hitting a rev limiter.. WTF.. So that is where I am, Once the RPMs get to 2.5k it acts as if the engine is hitting a rev limiter. I dont believe I screwed the maf up (I've screwed up plenty of mafs in my time so i know what not to do). Right now the CEL is still on so I am going to disconnect the battery to see if clearing the adaptation tables will help reset the ecu and get it running right. The real PITA is it is a work truck that I depend on to make a living, I need to get it up and running by this evening. FRAK !!!! Thanks in advance for any help. |
tried the battery disconnect to clear the ECU.. nothin doin.. Sooo now its off to find a scanner..
Code p0192 .. low fuel pressure. I have not been able to find any DIY or HOW to's on replacing the sensor. Anyone with a link ?
low fuel pressure can mean many things though. which sensor are you trying to replace? the main fuel pressure low issues i see are frp sensor, uvc harness, hpp, hpp gasket, and pcv and vcv
How many miles since you changed the fuel filters? I'd change those first if it's been awhile just to rule out any easy fixes
Thank you for the replies, Looks like I will try the fuel filter. Im new to diesels. German car's not a problem, but I am just overwhelmed with this monster right now. Partially because I just dont have time to devote to figuring it out. I need to get this rig ready for winter work. Thank's again for all of the replies.
I was told there is a fuel pressure sensor under the passenger side valve cover that I should take a look at. I dont know if there is any merrit to that or not but I will start with the fuel filter. Edit.. Are there any guides such as a chilton/bently/haynes that i should pick up that would help out ? Is one better than the other ? Last edited by Neel M3; 07-04-2012 at 10:59 PM. |
