03 7.2 srp1 install problems!! - Ford Powerstroke Diesel Forum
Old 03-17-2012, 08:17 AM
im installing the new pump and my pump came with the thread on oil line style and im trying to put my quick disconnect fitting on the new pump but they are the wrong size. what do i need to do?
Old 03-17-2012, 08:51 PM
Call whomever you bought the pump from. The SRP1 uses a larger threaded hole to prevent blowout so you can't swap your old ones but should still have quick connects. I have never heard of a threaded connection being used.
