96 7.3 wont start - Ford Powerstroke Diesel Forum
Old 02-29-2012, 06:17 PM
96 7.3 wont start
The truck acted like it was missing then i was driving it and was running great and then is was like I turned the key off just quit and now it just rolls and wont start any advice would be helpful
Old 02-29-2012, 08:26 PM
aussie=effie
7.3 wont start
CPS for starters, otherwise fuel pump
Old 03-01-2012, 05:22 PM
changed cps and fuel pump is new what else should I check it has a new adrenaline and ipr all fuses are good thanks for any help you can give Im just not sure what to check next
Old 03-01-2012, 05:37 PM
bump bump!!
Old 03-01-2012, 05:42 PM
Send a message via AIM to Maverick1701
did you check your oil level? HPOP oil level?
If oil is low the injectors wont fire which = no worky
Old 03-01-2012, 05:43 PM
anybody have any ideas
Old 03-01-2012, 05:44 PM
oil is full in resevoir and engine
Old 03-01-2012, 05:48 PM
the baconator
did you check the fuses under the hood?
Shaking the Bush Boss
check the IPR valve. The tin nut will back itself off and let the solinoid fall off the rod.
any other ideas i wish these were simple
