Are all these codes related some how - Ford Powerstroke Diesel Forum
Old 02-27-2012, 04:07 AM
Truck was running fine and all of a sudden Tow/Haul light started flashing and it started running like crap and set all these codes
P0760 P0763 P0769 TRANS P0261 P0264 P0267 P0270 P0273 P0275
Old 02-27-2012, 05:09 AM
Flashing tow/haul light is an indicator of a transmission fault. For finding out what all those codes mean check this web sight.
http://www.dtcdecode.com
Old 03-01-2012, 07:56 AM
Called a friend of mine that rebuilds tranny's and he told me that solenoid "C"
is the far right on the back of the valve body. After I replaced it the code will still not clear.
Started unpluging harness from trans and noticed the loom gone where the wires go by the cooler line. Inspected wires and found one that had rubbed through and has a coroded spot in it. Pulled on wire and it was coroded in half.
