05 powerstroke 6.0 overheating and smoking help!!! - Ford Powerstroke Diesel Forum
Old 02-25-2012, 09:54 AM
I have a 2005 250 diesel 6.0 and the other day it was smoking horribly white smoke out exhaust and was overheating. Cant find any water coming out around engine.can smell antifreeze. any
ideas?:
Old 02-25-2012, 10:45 AM
Head gasket!
Old 02-25-2012, 02:55 PM
There is no check engine lights or service engine lights on just saying water in fuel?
Old 02-28-2012, 08:27 AM
If it is not leaking anti freeze, but loosing it...and you can smell it and its smoking white(antifreeze)?
I think its probably your head gasket.
I also think that a common problem with a 6.0's? a lot of people say put arp headstuds ect in them for preventative maintenance so the headgaskets dont blow.
Not sure what your looking at for a fix, but my guess is it might be pricey?
hope you figure it out!
Old 02-28-2012, 11:38 AM
you're in the same boat as me almost, except i shut mine off before it overheated. most likely oil cooler, egr cooler, and headgaskets. not a cheap job to do. If its still running, i suggest drive it into a tree head on, make sure u put your seatbelt on and make sure you paid your insurance bill first!
Old 02-28-2012, 11:46 AM
Chapter Director
Send a message via AIM to Fantom
Wow, great first post. I can see you'll be a wealth of knowledge here on the org.
Old 02-28-2012, 11:49 AM
That would be a choice but I think that would hurt. If it's running, shut it off before it gets any worse. It does sound like head gaskets. Check to see if any antifreeze is left or if there's oil in it. It may just be a ruptured EGR cooler and the head gaskets could be fine but you would have to be very lucky. First thing to go is oil cooler then EGR cooler then coolant gets in the intake and lifts the heads. I'm sure others will chime in with more info. Also list a little more about the truck, like modifications, any kind of temperature monitoring, etc. It will help.
Old 02-28-2012, 11:56 AM
come on now, you wouldn't follow that advice?
Old 02-28-2012, 01:19 PM
Chapter Director
You're right, it was great advice, he must be ASE certified
Old 02-28-2012, 01:23 PM
Feedback Score: 5 reviews
I got a better one... drive it off a cliff., but make sure your seat belt in secured
BAHAHAHAHAHA
OP: fix the sucker and throw a SCT Tuner on and enjoy
