07 f-350 6.0 died
only 89k, had a bad lag on accel shut off would not start back up, let it sit and started fine, checked codes and nothing but a turbo low boost showed up, was going to take it to a dealer to try there scanner but it died and would not start on the way home, I had the same problem back when it was under warranty and the dealer said after two weeks that the injector harness had burned on the manifold. and that was only about 7k ago. Any one have the same type of issue I know it is probably posted here already but I need to be pointed in the wright direction. Thanks for any info. forgot to mention the scanner said I had 500psi at idle and it went up when reeving up the engine.
