Help!!! Large oil leak, and no start!!!! - Ford Powerstroke Diesel Forum
Old 02-18-2012, 10:02 AM
Question Help!!! Large oil leak, and no start!!!!
First off she's a 06' F250 6.0L CC 110K stock. It has had a small oil leak for quite some time from upper right rear of the block. Within the last few weeks I noticed the leak becoming larger (4" dia spots). Ok it on my s*!t to do list. Well it didnt make it that far. On my way home from work took a soft right and engine died. I pulled off and cranked it a bit and nothing, so I got out and saw a large pool of oil that only starts pouring when cranking. Got it home and looked at it this morning cranked it a bit and no oil leak can be produced. This is where im at. Oil is full, no oil in the top valley, fully charged batteries, good crank speed, and got codes P2291, and P2617. Im really leaning a high pressure oil leak but what would be leaking on the back side with that quanity of oil? Any help would be great and thanks for your time!!!!!!!!!!
Old 02-18-2012, 10:17 AM
It's HPO. The HPOP is back there. That's about all I know.
Old 02-18-2012, 10:21 AM
It's more in the center. It looks like im just going to have to tear into it and see what i see. I just hate to go in blind.
Old 02-18-2012, 10:31 AM
You said on the upper right rear. That's a very objectional direction.
Driver or pass side? The ICP sensor is also on the VC. Not sure which one. But it's back there too.
Old 02-18-2012, 11:02 AM
Sorry about that its the passanger side rear. And the ICP is dry.
Old 02-19-2012, 05:06 AM
I cant believe out of all the knowledge and experience on this site nobody has seen this.
Old 02-19-2012, 05:18 AM
Having the same type of problem right now..... amungst the other 6.0 issues that all seem to hit at the same time!! Only 80K on the truck. Can't wait to hear some input on this.
Was your oil dripping down the RR side of your block and onto the trans line? My oil levels are fine, but I'm blowing some smoke.
Old 02-19-2012, 07:47 AM
Ya gotta give it some time. I live on here, but most others don't
Sometimes it's just slow. So
Old 02-20-2012, 03:17 AM
Well I tore it down yesterday and as I thought I had a bad STC fitting. I also saw the rear cover is broken from the fitting blowing and slaming into the cover. Not really what i wanted to see but it is what it is. I will post pics and keep updating as I get the trans out, part pricing, ect.
Old 02-20-2012, 05:00 AM
Where is the STC fitting? Can't wait to see your pics to find out if that's what I'm facing as well.
Sent from my ADR6300 using AutoGuide.com App
Tags
leaking oil, no start
