Please help. Stuck And my truck is Making a bad noise - Ford Powerstroke Diesel Forum
Old 02-17-2012, 08:13 AM
Headed down town to get my taxes done and I turn on the road and it's making a terrible blowing noise when I accelerate. Is a loud leaf blowing noise?? What could it be. Hope someone has an idea. 04 6.0 6spd thanks
Old 02-17-2012, 09:53 AM
How cold was it outside when you ran it? Give it enough time to warm up? Was the noise still there after it warmed up?
Old 02-17-2012, 10:20 AM
The truck was warm and it's about 50 ish out the truck had been running 45 minutes prior to the noise. It's like the fans stuck on the blowing harder with the gas petal. Temp gauge goes up when I flip the key on and goes down. Start it it goes up then down a hair then up. Coolant running at 170
Old 02-17-2012, 12:18 PM
Can it be heard more from the exhaust outlet or under the hood?
Old 02-21-2012, 06:10 AM
intercooler boot pop off? that would explain the high egts and air noise.
Old 02-21-2012, 08:22 AM
It was the coolant temp sensor. Replaced it yesterday and it's good to go. Had the fan stuck on and my fuel pressure going crazy. Amazing what one tiny little sensor will do
Old 02-22-2012, 11:55 AM
Glad to hear you figured it out and you're back on the road! Thanks for updating us with the fix! Every bit we get to hear the better.
