Installed Wicked Wheel, now won't start! - Ford Powerstroke Diesel Forum
post #1 of 23 Old 09-15-2007, 05:15 PM Thread Starter
Stupidity pisses me off
sevenmalards's Avatar
Quoted: 9 Post(s)
Exclamation Installed Wicked Wheel, now won't start!
I just did the wicked wheel installation today. When I was done I started the truck and let it just run at idle for about 10 minutes. It was on the stock program. After it warmed up I hooked up my edge evo and set it on the extreme setting. When the programming was done it wouldn't start!??? Then I re set it back to the stock program. Still no start now. I replaced the CPS. Still no start. I pulled a code
P0603 PCM Processor (Keep alive Memory Error)
I have pulled this code before while the truck was drivable. I found a blown fuse for the "power point" and replaced it. Still no start. Now I'm charging the batteries and will try again in the A.M.
Any advice on what could have happened, or what the solution might be?
Thanks!
2006 F350 CREW CAB LONG BED KING RANCH
99.5 F350 Super Cab Long Bed, Dually.
SOLD
Originally Posted by SMKSTAX View Post
You are not right man, but i still think your funny as hell!
sevenmalards is offline
post #2 of 23 Old 09-15-2007, 05:18 PM
Rob
Rob's Avatar
Quoted: 2 Post(s)
does it crank over??? i had an issue with the bully dog downloader i had, i went to put it to stockm it worked, tehn wouldnt even crank over, i checked for codes, still no workie. it ended up making my PCM crap out. i had power, but no relays or pumps would come on, nothing. hope you get it figured out bud.
Audentes Fortuna Juvat
(Fortune Favors The Bold)
The Org. Staff reserves the right to
move, modify, delete or merge threads/posts
at our discretion, without explanation
at any time.
Rob is offline
post #3 of 23 Old 09-15-2007, 05:18 PM
Sounds like an ecm to me... does the "wait to start" light come on?
The KAM code is normal with a programer
forddieseltweek is offline
post #4 of 23 Old 09-15-2007, 05:45 PM Thread Starter
Quoted: 9 Post(s)
EVERYTHING is normal! All the lights come on, the Wait to start comes on, and goes off when it's supposed to, it cranks over, just doesn't start.
SOLD
post #5 of 23 Old 09-15-2007, 10:01 PM Thread Starter
Quoted: 9 Post(s)
anybody else have any suggestions?
SOLD
post #6 of 23 Old 09-15-2007, 10:23 PM
rankroddin250's Avatar
ive herad of this problem with edge im glad ive nevder had a problem with mine. check your fuses? thats the best oi can come up with
A well regulated Militia, being necessary to the security of a free State, the right of the people to keep and bear Arms, shall not be infringed.
The People of a free country should not be scared of their government, the government should be scared of their people.
rankroddin250 is offline
post #7 of 23 Old 09-16-2007, 06:57 AM
Slacker
Evil Eye's Avatar
Quoted: 210 Post(s)
Feedback Score: 4 reviews
Sorry, bud. Here's a bump to the top for ya.
Shawn Carlson
Proud Navy Vet
2005 F250, CCSB, 6.0 PSD, FX4 (The Sweet Unit is white)
2008 F350, CCLB, 6.4 PSD (Brad-the wife's truck is black)
Engine Mods:
Fluidampr
CCV Reroute (Reinstated)
4" MBRP Exhaust
MTW Stage 1 Turbo
Bulletproof 53V FICM
BulletProof EGR Cooler
BulletProof Water Pump
Riff Raff Intercooler Boots
Gogo Diesel Direct Drive Solenoid
BulletProof All-Aluminum Radiator
BulletProof All-Aluminum Intercooler
BulletProof Oil Cooler System w/ Bypass Filter
SCT w/ Custom Tunes (TSD, DJ's, Innovative, Gearhead, QuickTricks)
Exterior Mods:
Bilstein 5100 Shocks
Icon Adjustable Trac Bar
Firestone RideRite Air Bags
BDS Dual Steering Stabilizer
Aluminum Finned Differential Cover
Reese 16k Manual Slider 5th Wheel Hitch
Icon 2.5" Leveling Kit w/ F-350 rear blocks
20" BMF Novakanes wrapped in 33" Nitto Terra Grapplers
Evil Eye is offline
post #8 of 23 Old 09-16-2007, 08:16 AM
Lonno's Avatar
Cranks but no start, is that fuel not delivering. I would check all 30amp fuses. I blew one the other day and mine wouldn't start. I stole one from the trailer brake and it fired up.
1970 F250 Crew Cab rebuilt/restored w/Cummin s 4bt
8v, M5R2 Tranny, VE pump, DennyT stage 2 pin, M&H Dynamic Timing, 3200k gov spring, Hx30/Hx35 Twins, 40hp styx, smoke screw screwed, star wheel cranked, Hydroboosted
91 Gillig Phantom, Converted transit bus, 6v92 Detroit Diesel
6500 Watt Diesel Generator on board
All Diesel
All Day
Lonno is offline
post #9 of 23 Old 09-16-2007, 08:55 AM
Try to remove the program all together and see what it does. I have had a bunch of juice with attitudes do thats. I Have had to return them to edge and get new ones. Then everything works fine. Try to remove it and see if it starts.
Performance Oil Products is offline
post #10 of 23 Old 09-16-2007, 10:04 AM Thread Starter
Quoted: 9 Post(s)
I've had the batteries unplugged for about 2 hours. I'm going to hook them back up, then try to reinstall the stock program with the Edge Evo one more time. If nada after that I'll have to have it towed
SOLD
