Go Back   Ford Powerstroke Diesel Forum > Specialty Forums > 911 Urgent Situations > Engine 911
Old 09-15-2007, 10:40 AM
sevenmalards sevenmalards is offline
I GRADUATE IN 2 DAYS!!!!!
Exclamation Need URGENT advice
I'm taking off my turbo to install a wicked wheel and I'm stuck at the exaust bolts behind the turbo. I have everything else off. I started to remove the first bolt and I got to a point where it won't come out anymore and I'm affraid to break it. Can I install the new wheel without removing the entire assembly? Please help!
Thanks.
Also how do you get the back exaust bolt out? From the top or bottom?
Old 09-15-2007, 10:43 AM
shu873 shu873 is offline
hillbilly keyboard racer
I can't help you there man, but the bumps for free! Good luck!!!
Old 09-15-2007, 10:57 AM
bigcountrysg bigcountrysg is online now
duct tape & zip ties
http://www.blackclouddiesel.com/Tech...on%20Guide.pdf
Sevenmalards follow these instructions. This is to install the ww with out removing the turbo. I plan on doing this myself tomorrow. I am going to use the instructions I provided for you to install mine.
Old 09-15-2007, 11:01 AM
Awesome link BC, way to come through!
Old 09-15-2007, 11:02 AM
I do what I can, just a simple google search.
Old 09-15-2007, 11:15 AM
Man I can't thank you enough! I was just under the rig thinking about dissconnecting the exaust pipes at the headers and pulling those up with the turbo! Then I thought "I better go check the ORG and see if I have some advice!" GLAD I DID!
Thanks a million!!!
Old 09-15-2007, 11:21 AM
Thanks a million!!!
Don't thank me till you have it done. Then let me know how this goes for you. As I am going to do the samething tomorrow.
Old 09-15-2007, 05:10 PM
Okay it wasn't too bad. When you take off the clamp for the down pipe you need to be able to drop the pipe a little more so crawl under and unhook a couple of the hangers (didn't say this in the instructions) but it's necessary. Other than that it was okay.
Old 09-15-2007, 05:14 PM
Glad it went good for you!
Old 09-15-2007, 05:16 PM
It went good, until I programmed the Edge Evo and now it won't start!
