she just died...
here i am driving to a hott date and it seems as my truck ran out of fuel but i had half a tank and i know there is fuel in it....it started to sputter and then just died...she will crank and sounds like it wants to stat but wont..i think its a fuel pump or sending unit but im not sure.. any one with similar problem? hell maybe its injectors for all i know...i am running a 2000 f250
Can you hear the fuel pump running? Check the fuel pressure.
Also, does the tach work when you try to crank it? |
tach
the tach does work...where do i go abouts listening for the fuel pump? is it in the tank or along a rail some where? also what exactly am i listening for? thanks! i had a friend turn the key while i lookin it the fuel bowl on the filter and nothing came out. dont know if that would have anything to do with it
Could be Cam Position Sensor. Have you checked the fuel filters?
And WELCOME to the Site! Last edited by Big AL; 09-04-2007 at 05:07 AM. |
Welcome to Powerstroke.org ![]() ![]() ![]() ![]() ![]() Your problem sounds like a CPS to me. |
common huh?
i have been reading on this problem from other posts on here...seems pretty common. is there any way to test to see if this is the problem before i go buying parts...after this is replaced will i have to prime the engine?
cps is only like 30 bucks now. No real way to test it besides maybe an OHM's meter - but you want a spare anyways so throw the new one in and put the old one in the glovebox incase it's not the problem.
You had your fuel filter lid off and your buddy turning the key and no fuel was being sprayed everywhere???? If that's the case - I'd definitely check the fuel pump. It's on the framerail right under the drivers side driver door. When you turn the truck to the on position you will hear it turn on, or you won't LOL! |
ok so i pulled the line coming out of the fuel pump and turned the truck over and nothing was shooting out so i am being led to believe that fuel should have been pouring onto the ground if it wasnt a bad pump correct??
If the tach is working it is probably not the CPS. The fuel pump should work with the key on.
